Old 09-22-2009, 11:27 AM
Clay White Clay White is offline
purlin-brace system
The 2x4 purlin was lying flat, rather then on edge.
I'd think this would be a defect , not carrying the load properly, but I didn't any roof sag, etc... 1981 home.
What do you all think?
Clay
HomeGauge Reports
Old 09-22-2009, 11:59 AM
Raymond Wand Raymond Wand is online now
Re: purlin-brace system
Clay
Purlins to my knowledge are always on their side - 3.5" side in your case with a 2x4.
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
Old 09-22-2009, 12:37 PM
Jerry Peck's Avatar
Clay,
To clarify, your title is "purlin-brace system" but your post was about the "purlin"?
Or was your post about the "purlin brace"?
Purlins are required to be the same size as the required size of the rafters, which would mean that the pulins were installed vertical (1-1/2" wide by the rafter height for the height) and not flat-wise (1-1/2" high by the rafter height for the width).
Old 09-22-2009, 03:51 PM
John Goad John Goad is online now
What was the size & span of the rafters?
Some times you will find that the size & span installed are well within the limits of requiring mid-span support.
Clarksville Home Inspection
JW Goad
Old 09-22-2009, 09:57 PM
Michael McCann's Avatar
Michael McCann Michael McCann is offline
As a Structural Engineer, that sounds really strange to me - not normal at all.
Is there any way to post a picture or sketch of the condition?
And, in reference to the "purlins", are you speaking of ceiling joists in the attic, or rafters at the roof as being 2X4 flat? Or something else?
Michael McCann
MMC Engineering (Civil and Structural)
Everett, Washington
  #6 (permalink)
Old 09-23-2009, 05:17 PM
Stacey Van Houtan Stacey Van Houtan is offline
No one has discussed the main point. The roof is performing. If we did all our inspections on a perscerptive basis ( as related to attic framing) Then every home with 2x4 rafters would need repair.
  #7 (permalink)
Old 09-23-2009, 05:43 PM
Jerry Peck's Avatar
Quote:
That is anything but the main point.
If it is not constructed properly, then it is likely "under-designed" and "under-built" and "the test of time" to which you are referring to without naming is not a "test of time for the better" but a "test of time for the worse" to see if it has failed ... YET.
They very well might.
Likewise, and to the opposite, any home built with 2x4 rafters SHOULD be addressed.
The purpose of a home inspection is not to look at a tin shanty with no framing and say 'Yeppers, it sure looks like the tin is still standing.', but to look at that tin shanty with no framing and explain to your client that 'I really have no idea why it is still standing, there is no structural aspect or components to hold it up. I doubt you will be as lucky as the previous owners, resulting in you having to pick up the pieces as it falls down and rebuilt it properly - which could become quite expensive.'
  #8 (permalink)
Old 09-23-2009, 07:34 PM
It seems that most of the time the purlins are wrong & when they do get the purlin & support spacing correct the support is placed under the flat 2x4 nailed to the bottom side of the rafters instead of supporting the "on edge" part. This puts the stresses on the fasteners instead of the member.
I did see a roof structure yesterday that was textbook, & I mean in a good way. I was impressed & asked who had done the framing & they said he had gotten too expensive & were no longer using him.
JW Goad
  #9 (permalink)
Old 09-23-2009, 07:48 PM
Jim Luttrall Jim Luttrall is online now
And we wonder where all the good carpenters have gone!
Allen, Texas 75002
  #10 (permalink)
Old 09-24-2009, 09:10 AM
I did not mean that the test of time is always the correct method. BUT If you think that all homes with 2x4 rafters need repair i disagree. Do you know why for the same spans the code chaged from 2x4s to 2x6s for rafters and for that matter for the same span 2x8s to 2x10s for floor joist?
  #11 (permalink)
Old 09-24-2009, 10:26 AM
David McGuire David McGuire is offline
I am just getting into this, but I'll take a stab at this one. Was it because of increased insulation?
David McGuire -- McLouth, KS
  #12 (permalink)
Old 09-24-2009, 11:15 AM
Some framing methods and size of materials have changed over the years. NOT becuase of structural failure but becuase the fiber creep of the wood caused bowing and saging or excessive bounce in floors. A change in how we define servicabiltiy. This is cosmetic. As I tell my clients you can't expect a old house to be a new house.
  #13 (permalink)
Old 09-24-2009, 06:25 PM
Jerry Peck's Avatar
"but becuase the fiber creep of the wood caused bowing and saging or excessive bounce in floors. A change in how we define servicabiltiy."
More accurately, how one defines lack of serviceability.
"This is cosmetic."
No, that is a defect. You said so yourself: "becuase the fiber creep of the wood caused bowing and saging or excessive bounce in floors"
That is not "cosmetic", that is "under-designed" and "under-built".
Does that mean it was "under-designed" and "under-built" intentionally?
Nope. Just means that "it was", intentionally or not.
Older homes show the learning curve of acceptable building practices, and of UNacceptable building practices ... "fiber creep of the wood caused bowing and saging or excessive bounce in floors" is NOT the result of an acceptable building practice, it is the result of an UNacceptable building practice.
  #14 (permalink)
Old 09-25-2009, 10:10 PM
John Kogel's Avatar
John Kogel John Kogel is online now
Where I live, we went to 2X6 because you can't buy a decent 2X4. The good Douglas fir gets shipped out, so we build with spruce and pine. Check out this 1950's attic. I call this a knee wall, and the flat top plate is correct here. I never use the word 'purlin'. Nobody knows what that is.
  #15 (permalink)
Old 09-26-2009, 07:59 AM
Jerry Peck's Avatar
Quote:
'Ceptin' that the top plate should have been doubled when laid flat.
  #16 (permalink)
Old 09-26-2009, 11:18 AM
John Kogel's Avatar
Quote:
You are more correct than me. There could be a slight sag in that 2X4 between the braces. I don't ever see a double plate but it would no doubt be better. On the opposite side of this roof, there's a chimney and a valley so they just popped in one brace.
These three pic are from a 20 yrs younger home, lower pitch with plywood sheathing. This roof is like a trampoline to walk on.
I recommended an upgrade for this one.
Manufactured trusses put an end to the 2X4 rafter and that was a good thing.
  #17 (permalink)
Old 09-29-2009, 02:52 PM
Brad Peterson Brad Peterson is offline
Some framing standards are unclear, but the Perlin system is oneway only. Perlin is a 2x member that runs 90 degree to the rafter at 1/3 rafter span or less. A perlin brace is notched to fit the angle of the perlin and angled to a BEARING wall and nailed to the wall and ceiling joist. Collar ties are 2x members that rest on top of the perlin and are nailed to the rafters and perlin above perlin braces. The notching of the perlin braces to fit the perlin and the weigh load from the rafter is why it needs to be installed as a 2x4 not a 4x2. An excellent reference guide to building standards is the Architectural Graphic Standards
Brad Peterson
Tri-City Inspection Agency, LLC
  #18 (permalink)
Old 09-29-2009, 04:57 PM
John Kogel's Avatar
Brad, I know exactly what you're saying and you must be from somewhere west of the Mississippi, because Ray Wand from out East does not agree with you.
100 yrs ago, a purlin was something else.
I have pics of west coast purlins and collar ties.
Last edited by John Kogel : 09-29-2009 at 05:22 PM. Reason: missed the spellin of dat rivr yonder :>O
  #19 (permalink)
Old 10-02-2009, 04:32 PM
Jerry Peck's Avatar
Quote:
Brad,
Not quite right, and first, it is "purlin" instead of "Perlin", and second there are two totally different meanings and components of what a "purlin" is.
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Similar Threads
Purlin braces Gary Mohel Attic Areas: Home Inspection and Commercial Inspection 1 07-31-2009 01:05 PM
CAT IV system Scott Patterson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 05-18-2008 12:05 PM
Questionable purlin? Scott Medlin Structural Components: Home Inspection and Commercial Inspection 4 10-03-2007 07:21 PM
Purlin brace Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 1 07-20-2007 01:13 PM
Odd Purlin Brace (?) System Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 3 04-14-2007 07:13 AM
vB.Sponsors
Ad Management by RedTyger
