Thread: Grill in Your Fireplace
03-14-2013, 08:04 AM #1
I saw this yesterday. A gas grill in a fireplace. This is an early 60's home with a gas conversion in the fireplace. The damper was working and there wasn't an outside gas shutoff so this was a non-complying conversion.
But you can grill that steak on a cold snowy winter's evening in the comfort of your family room.resized.jpg
Similar Threads:If you choose not to decide, you still have made a choice.
03-14-2013, 02:14 PM #2
Re: Grill in Your Fireplace
Where was the gas shut off valve or did you not find one at all?
03-14-2013, 02:17 PM #3
03-14-2013, 02:46 PM #4
03-14-2013, 03:22 PM #5
03-14-2013, 04:23 PM #6
I like rare please....
03-19-2013, 03:15 PM #7
I have seen these or similar a couple of times. The grill portion in the units that I have seen actually had burners that appeared to be shortened versions of a gas grill burner mounted under the grilling surface. The units I checked actually seemed to put off enough heat to do a good job searing a steak.
03-20-2013, 06:22 AM #8
