Results 1 to 15 of 15
    Apr 2008
    McKinney Texas
    Default Look at this photo. Are pan drain line and TPR drain line allowed?
    Look at this photo. Are pan drain line and TPR drain line allowed to be connected together like in this photo ?
    Default Re: Look at this photo. Are pan drain line and TPR drain line allowed?
    "Are pan drain line and TPR drain line allowed to be connected together .."
    No
    Nope, the TPR line needs to be independent. Also needs to go to a visible location, if that is not doing so.
    GS: No, and no AHJs in the D/FW area will allow it, to my knowledge.
    No, it is not allowed as others have already said, but that installation is very common for homes in the area that are over 10-15 years old. I see them all the time and must confess I never worry too much about it. The check valve in theory should stop or slow the blow back into the pan if the TPR trips.
    Apr 2008
    McKinney Texas
    I am just curious but where does it state this type of connection should not exist ? In IRC 2803.6.1 it reads."..the discharge shall be piped full size separately to the floor..."... I guess the key word is separately, so I guess that is where it is stated ? Everyone on here is smarter than me. I am just wondering. Or maybe it is the plumbing codes which I do not have a copy of.....Anyway...
    Gene
    Gene
    GS: The key term is "separately".
    Believe me, everyone on this forum is not smarter than you. A few examples come to mind: TM, RB, ML, . . . it is a very long list.
    Apr 2008
    McKinney Texas
    Thanks.
    Gene
    Richard Stanley's Avatar
    Richard Stanley Guest
    "Everyone on here is smarter than me."
    That is only your imagination...
    Mount Pleasant, SC
    How long has it been wrong to plumb it 'uphill'?
    www.atozinspector.com
    imported_John Smith's Avatar
    imported_John Smith Guest
    Howdy Gene,
    I think it was an aggie install.
    Quote Originally Posted by Mike Gault View Post
    Since before the IRC came into being, but I can't give you a date.
    I have been doing inspections since 1995 and it was already established as wrong long before that.
    JL: It has been wrong since Watts began manufacturing combination TPR valves.
    When was that AD? I would say something smart connected with age... but I won't, I had a late report writing night and the smart azz cells have not come to life yet.
    JL: The short version: the late 1920s. The long version:
    Watts Industries, Inc. -- Company History
