12-20-2009, 10:43 PM #1
surface-mounted lamp cordextension wiring
what is surface-mounted lamp cordextension wiring?
12-21-2009, 06:04 AM #2
Re: surface-mounted lamp cordextension wiring
Are you asking about a lamp cord attached to a baseboard?
If so it is incorrect. It should not be used as a substitute for permanent wiring.
Has Ritchie highway cleared up yet?
12-21-2009, 10:20 AM #3
What does your question pertain to? A chain & hook supported plug-in lamp (such as was very popular in the 50s, 60s and 70s)? A pendant lamp cable, low voltage cable for cabinet lights (such as "hockey pucks")?, rewiring a chandellier (internally or its supply cord)? Replacing a lamp cord/rewiring a lamp? Or something else completely?
What is supposed to be surface mounted, the cord or the lamp itself? Cord & plug supplied or what?
Point being the context your finding this statement and how it is applied might afford a helpful answer.
Extension cords are not a substitute for permanent (system) wiring.
12-21-2009, 10:21 AM #4
12-21-2009, 04:17 PM #5
i found it here while i was snowed in and just doing some learning and i wasn't really sure what it was referring to. Your questions were basically what i was wondering too.
Evaluating your home's wiring system
this is the paragraph toward the very end:
A visualinspection of insulation on accessible circuits will usually determine whether additional tests should be performed by an electrician. Look for unprotectedwire runs through ducts and other inappropriate areas. Inspect for evidence of"handyman tampering" (e.g., unconventional splices), and if found in onelocation, expect it to be more widespread. Check for surface-mounted lamp cordextension wiring. It is dangerous and must be removed. It is best to remove allunused wiring or wiring that will be abandoned during rehabilitation work toavoid future confusion or misuse.
so is it just referring to extension cords used as permanent wiring?
12-21-2009, 04:21 PM #6
12-21-2009, 04:34 PM #7
12-21-2009, 04:39 PM #8
Seems that entire paragraph is referring to beyond useful life, unsafe, and unconventional & unsafe adaptations to an electrical system.
12-21-2009, 08:45 PM #9
Something like this. The carpet tack adds a touch of excitement to an otherwise dingy basement suite.
