Results 1 to 35 of 35
Thread: Beat this:)
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Beat this:)
    This was leading to an old, what looked like, WWII radio or transceiver.
    Sep 2009
    Twin Cities, Minnesota
    Default Re: Beat this:)
    Found this hanging about neck level in the basement. The crumpled paper taped to it said, "Caution, Live Wire"
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Not bad, not bad at all
    Jonathan Cartwright's Avatar
    Jonathan Cartwright Guest
    Garage door opener connection.
    That old ham radio guy wasn't scared, it's only 120 volts.
    I'll play. Here you go.
    From my home inspection slaying's the last couple days.
    Be sure and check out the "bong" in the child's room on the end table. WTF?
    Ridgewood, NJ
    Smile Re: Beat this:)
    Nice sword.
    What he really wanted to say was, nice bong.
    I like the living room.
    Sep 2009
    How many times has that kid fallen out that window??
    -Jon
    Rick
    The Sword!
    Was that to fight the pot heads and rats off?
    From this mornings inspection! This is above a shower!
    Also a picture of the garage! Just to keep Rick's folks from not feeling to bad!
    Scott,
    Check out this light fixture. Its not within the shower space, but look out if you have a wet head (laughs a little) getting out of the shower.
    Jimmy the water thermis be leakin again, where da dogs water bowl.
    Charlotte, NC
    But it LOOKS so good !!
    Talking Re: Beat this:)
    Dammit! I'm trying to write a report. Now I got the giggles! Thanks a lot!
    Hee Hee
    George Sharrett's Avatar
    George Sharrett Guest
    OK,
    Had to share too.
    "Posts! We don't need no stinking posts!"
    Peter Drougas's Avatar
    Peter Drougas Guest
    I've been meaning to post this photo. So thank you for this thread.
    Coffee container electrical box. The rest of the house wasn't much better!
    That one is going to be very hard to beat. LMOA.
    Dave Gilstrap's Avatar
    Dave Gilstrap Guest
    OK I found this yesterday, doesn't this just say love.
    Y'all need to post some of your "special" finds over on Home Inspector Facebook page... Welcome to Facebook | Facebook
    Kary Krismer's Avatar
    Kary Krismer Guest
    Quote Originally Posted by Dave Gilstrap View Post
    The second toilet was probably installed back in 2001, when anti-French rhetoric was causing people to get rid of their bidets. ;-)
    Mark Beck's Avatar
    Mark Beck Guest
    Quote Originally Posted by Dave Hahn View Post
    At least put em on a GFI
    Greg Roberts's Avatar
    Greg Roberts Guest
    Homeowner said it's ok as long as it gets outside. Look at the wiring through the wall at the bottom right.
    David Wetmore's Avatar
    David Wetmore Guest
    Default Re: Beat this:) A return air vent!
    For perfect circulation throughout the home.
    Denny Waters's Avatar
    Denny Waters Guest
    Humboltd County
    Today I found a opening that had been cut into a kitchen cabinetry to feed some cable wiring into the kitchen for a television on a counter top.
    On the opposite side of this wall was a fireplace with metal firebox.
    I held my camera over into the opening and snapped away. You can see the side of the firebox, but check out all the other things that was near this firebox.
    One picture is a upshot of this area.
    Last pic is supposedly roof repair.
    Tom Camp's Avatar
    Tom Camp Guest
    I had to add this one, yes the conductors were live. I found this in a storage area.
    Steve Karr's Avatar
    Steve Karr Guest
    One thing about Jonathan Cartwright's garage door opener wiring: At least it is a dedicated receptacle...
    Kenneth Whitelaw's Avatar
    Kenneth Whitelaw Guest
    just plug it in!
    plumber? we don't need no stinkin' plumber!
    Lou Romano's Avatar
    Lou Romano Guest
    Who needs that factory made stuff!
    A thing of beauty today. High efficiency furnace with the condensate drain to the water heater pan, which of course went nowhere.
    Eric Shuman's Avatar
    Eric Shuman Guest
    Here's a couple.
    The hot bus bar and breakers for the this panel are in the "updated" panel on the exterior of this wall.
    The plastic in photo two is so the leaking fill valve wont spray water out from under the lid when it is in place. The tenant was pretty proud of this one.
    ray jackson's Avatar
    ray jackson Guest
    I thought I'd add what I can.
    This is new wiring for the rooftop A/C. This was actually done by a local contractor.
