Results 1 to 11 of 11
03-22-2012, 04:07 AM #1
Gap Between Deadfront Cover and Breakers
I saw this yesterday and was wondering what the maximum allowable gap is between the deadfront cover and breakers. This one measured at 6/16" at the largest gap around the main disconnect. I'm inclined to say it should be corrected regardless but was wondering how much is allowed.
Similar Threads:"It takes a big man to cry. It takes an even bigger man to laugh at that man". - Jack Handey
03-22-2012, 05:01 AM #2
Re: Gap Between Deadfront Cover and Breakers
Was that a panel with the two adjusting screws on the dead front so it could be adjusted? If not, I don't think I would say much simply because not much can be done about it. I see that from time to time and I have never given it much thought about calling it out as a problem.
03-22-2012, 05:18 AM #3
Not adjustable.
03-22-2012, 05:37 AM #4
Is it a listed piece of equipment? If so then it's a listing agency issue,IMO. Is the panel a 3R type, they are not adjustable?
03-22-2012, 09:44 AM #5
Any time I see a poor fit at a deadfront, I suspect a field-modification or an incorrect (replaced) deadfront.
03-22-2012, 09:54 AM #6
There should be no gap around the circuit breakers.
Now to ask some questions:
Was that a recessed panel?
Was the deadfront part of the cover ( like a residential panel)
If so it could be a case of the panel can mounted too far back. The cover will not allow the interior cover to fit correctly. The corrective action would be to move the panel can out.
As per NEC 312.2 the can can not be set back more than 1/4" in walls comprised of noncombustible material.
In walls of wood (paneling) or other combustible material the can shall be flush or project therefrom.
03-22-2012, 11:14 AM #7
03-22-2012, 03:41 PM #8
... Oh, I get it now ... 3/8" ...
The cover should fit 'against' the breakers to close off the gaps. Good question as to how tightly "against" that would be.
I would say that the cover should basically cover the gaps, otherwise something is wrong, either not adjusted (some interiors are adjustable as to how far in/out they set) and some do not have any adjustment, they are made to fit properly when everything is properly in its place.
03-22-2012, 04:16 PM #9
well seeing how it was stated that it is a recessed panel, the interior "deadfront" is part of the cover, and the interior is not adjustable then My money is on the panel can itself was installed properly and the correct fix is to move the panel can out.
03-22-2012, 04:23 PM #10
03-22-2012, 04:54 PM #11
