Results 1 to 30 of 30
Thread: Not a P-trap
06-02-2013, 09:43 PM #1
Not a P-trap
So, I know what p-traps, s-traps, drum traps and running traps are. But, what the heck do you call this????
Similar Threads:Department of Redundancy Department
06-03-2013, 03:41 AM #2
06-03-2013, 05:47 AM #3
Re: Not a P-trap
My first thought was "ART". Something to behold.
What are the extra supply lines off of the valves going to?
06-03-2013, 07:24 AM #4
Re: Not a P-trap
Sprial trap? Looks like it meets all criteria of a P-trap. Thanks for sharing it.
06-03-2013, 08:18 AM #5
Re: Not a P-trap
That’s a plumber's heart trap, so the wife knows how appreciated she is when cleaning, think I hear a frying pan whistling through the air…
06-03-2013, 08:33 AM #6
06-03-2013, 10:13 AM #7
Re: Not a P-trap
06-03-2013, 11:13 AM #8
Re: Not a P-trap
That would be your standard variety Q trap.
06-03-2013, 11:33 AM #9
Re: Not a P-trap
Artistic for an open undercounter view. All done in brass. No way to disassemble it when you got a clog in it so it is a real "_itch" to clean. Basically a "P trap" sideways and then connected to the drain line.
Sure makes the faucet lines look "plain Jane"
The plumber had "Time on his hands" for this is gonna be a "witch" to replace as nothing like that is sold.
Maybe he does not know the alphabet. So it could be GREEK for "P"
06-03-2013, 02:52 PM #10
Re: Not a P-trap
The person who did that is a musician. S/he created a "treble clef trap."
06-03-2013, 03:20 PM #11
Re: Not a P-trap
Obviously the very rare "Pretzel" trap in the wild.
877-466-8504
06-03-2013, 03:55 PM #12
Re: Not a P-trap
Must be an @ trap.
06-03-2013, 04:56 PM #13
Re: Not a P-trap
I dunno ... looks like it could suffer from the problems that an 'S' trap suffers from, for the same reasons ... that curls up and dumps down into the wall arm, which is effectively what an 'S' trap doe (except the 'S' trap continues down into the floor, but once the water is up to, and over the top - I doubt there is much difference from an 'S' trap.
My first thought was that of the music clef too, glad to see that I was not alone in seeing that.
06-03-2013, 06:59 PM #14
Re: Not a P-trap
You people need to get out more "_" That is the world famous sheep horn trap.
06-03-2013, 08:40 PM #15
Re: Not a P-trap
Nautilus trap
06-04-2013, 03:44 AM #16
06-05-2013, 04:46 AM #17
Re: Not a P-trap
I will have to admit that style trap is a first for me.
06-05-2013, 08:52 PM #18
Re: Not a P-trap
I did not actually inspect the house, so I don't know what other oddities it held. I was in upstate N.Y. at the time for my daughter's college graduation. It is in the Vanderbilt mansion in Hyde Park. I just thought I need to take a pic and share it with the board.
I suspect Mrs. Vanderbilt did not care about how easy it was to clean or if it ever clogged. She had a small army of 30+ servants to make sure everything worked perfectly.
06-05-2013, 09:54 PM #19
06-06-2013, 01:01 PM #20
Re: Not a P-trap
That is a vintage manufactured brass S-trap for a sink or lavatory. If original or early replacement it would have originally been plated with chrome if in a service area (kitchen/scullery/sink closet/laundry/gen servants' hall) or more likely silver,, if it was at the Vanderbilt Hyde Park mansion.
See vintage catalogs 1896 through about 1910-ish.
The cleanout was standard, as it was also with the U-trap.
06-07-2013, 02:21 PM #21
Re: Not a P-trap
Chrome or Silver? How about Nickel?
Gunnar, thanks, that explains the lack of flash.
You couldn't resist inspecting the Vanderbilt's plumbing, eh?
06-07-2013, 09:26 PM #22
Re: Not a P-trap
Yes, really, Silver plated brass for the exposed drain & trap plumbing except for some of the service areas, where it was indeed nickel plated, I can't explain why I typed Chrome since there is no evidence a chromium layer was plated over the nickel (brain glitch while typing) plating. Thanks for catching that John.
From: p. 206 (234 of 487) Vanderbilt Mansion A Gilded-Age Country Place; Vanderbilt Mansion, National Historic Site, Historic Resource Study; Albee P., Berger M. Foulds, H.E., et al, 2000; National Park Service, Northeast Museum Services Center, Boston, Mass. 2008.
Originally Posted by NPS Historic Reserve Study
Gunnar,
Originally Posted by Gunnar Alquist
You might enjoy the report referenced above. The original water distribution system was interesting, as was the proliferation of shower baths, amongst other areas which might be of interest.
Here is a link: http://www.nps.gov/history/history/online_books/vama/vama_hrs.pdf
06-08-2013, 04:56 AM #23
06-08-2013, 06:55 AM #24
Re: Not a P-trap
I've been through their place in Ashville, yes, same people, if anyone is going near Ashville, I highly recommend going through that place - it is amazing ... even more so today because of what they were able to do 'back then'.
They also built a huge place in Florida to 'winter in', I don't recall how often they used it though.
With money like they had, if you wanted something and it was not available, you found a person smart enough to design what you wanted and build it.
06-08-2013, 07:23 AM #25
Re: Not a P-trap
John, yes. They don't allow use of a flash because they say it will fade the fabrics.
Oh, like you don't notice improper handrails, stairs or lack of smoke alarms when you go to people's houses!
Thanks H.G. It does look interesting. Certainly time-consuming.
One unrelated thing that I noticed. While, as Jerry indicated, money can buy you many things that are uncommon and useful. However, the decor was amazingly gaudy. Clearly, money cannot buy taste or class.
06-08-2013, 06:07 PM #26
Re: Not a P-trap
Cleaned up pic for ya
06-09-2013, 12:32 PM #27
Re: Not a P-trap
Ron,
Thanks for going to Hyde Park and retaking the photo for me. It's amazing how similar it is to mine!
06-10-2013, 07:19 AM #28
Re: Not a P-trap
That is an "Apestaart" Trap - Dutch for "monkey's tail" also one of the terms used for the @ Symbol. Also could be one of these below
snabel - Danish for "elephant's trunk"
kissanhnta - Finnish for "cat's tail"
klammeraffe - German for "hanging monkey"
kukac - Hungarian for "worm"
dalphaengi - Korean for "snail"
grisehale - Norwegian for "pig's tail"
sobachka - Russian for "little dog"
Apollo Home Inspection
St. George UT
06-10-2013, 09:40 AM #29
Re: Not a P-trap
Rotate that image to the right, and you will see it is a "G" trap.
06-10-2013, 08:53 PM #30
Re: Not a P-trap
) we know it is *not* a "P"-trap ... just like Gunnar said in the title to the thread.
