Results 1 to 12 of 12
Thread: Google Earth
03-01-2014, 01:31 PM #1
Google Earth
I just stumbled upon a pretty feature in Google Earth. You can scroll back to 1994 to look at overhead shots. I just used it to verify when a roof was replaced when there was some question and I couldn't find a date on a flashing.
Maybe this is old news but if you don't know about it give it a try.
03-01-2014, 06:03 PM #2
Re: Google Earth
I didn't know that. I have to check it out.
03-02-2014, 01:08 AM #3
Re: Google Earth
I don't see any option to select dates. How do you get there?
03-02-2014, 04:10 AM #4
Re: Google Earth
03-02-2014, 07:32 AM #5
Re: Google Earth
I tried and found that as you go back in time, the resolution gets pretty bad. At least from my perspective. I can see how it might allow you to narrow down when a major change was done, such as an addition. But determining when a roof was replace might be sketchy at best.
03-02-2014, 08:51 PM #6
Re: Google Earth
I had the same experience at first but I found from clicking on a given year a couple times or just moving up and down the slide a bit it would be much more clear sometimes. Seemed kind of strange and "glitchy" but I did get it to work great and nail down a roof being changed between 2006 and 2007.
03-03-2014, 07:15 AM #7
Re: Google Earth
The quality of the photos change pretty dramatically.
At my house, the previous owner added a large barn without pulling any permits. Two years ago, the assessor pulls up with satellite photos showing the barn and telling me he had gotten the bright idea of comparing satellite photos to the tax records. Oh and by the way, my taxes are about to go up. He could tell by the chronology of photos, that I hadn't put the barn up, but he didn't really care, he was there just for the revenue.
03-03-2014, 07:44 AM #8
03-04-2014, 04:05 AM #9
Re: Google Earth
It is easy to see that the imagery has improved considerably over a fairly short time frame. The "gaps" in the dates or times for images are due to the number of satellites covering huge areas, it is just impossible to have a new high resolution photo of each grid square each month. Maybe if the NSA would share some of their satellite imagery with Google Earth...
03-04-2014, 04:51 AM #10
Re: Google Earth
03-04-2014, 05:35 AM #11
Re: Google Earth
03-04-2014, 05:58 AM #12
Re: Google Earth
Here's a photo showing the time bar. Click the clock in the upper left corner and then move the slider to find the dates when
the satellite took a photo.
