Results 1 to 4 of 4
    Geoffrey Smith's Avatar
    Geoffrey Smith Guest
    Default One of the worst I've seen!
    Saw this yesterday: a rubber natural gas extension running from furnace to fireplace.
    First of all, there's no clamp on the rubber hose. Second, it's a rubber hose used in an interior bathroom.
    It runs through the house:
    To the outside - directly below a sliding glass door, back inside to the fireplace.
    Any recommendations or further problems seen here?
    Thanks.
    -Geoffrey Smith
    Default Re: One of the worst I've seen!
    That is CSST with a lightning strike outer covering - it is made for gas - it is not what you described it to be.
    Now, the installation of it is ... well ... leaves A LOT to be desired.
    Lansdale, PA
    If you thought that was a rubber hose you need to spend more time during the inspection actually inspecting and not jumping to conclusions. Spending more time leaning about materials and methods would also be advisable.
    Thanks Jerry. I appreciate it.
Tags for this Thread
