    Default Water heater in a garage, protection
    I had a realtor call me about a water heater being protected in a garage.
    In plain English (US English) what if any protection should a water heater have in a garage that is already 18 inches off of the floor from vehicles damaging them?
    Default Re: Water heater in a garage, protection
    A steel post like the ones you see (or maybe you don't, but they're all over around here) protecting gas meters outside.
    Ted, here is a diagram that I stole here.
    I just talked to McKinney Building Official about this and he said they look at it on a case by case basis and the protection could be an alcove, curb, etc. It is left to the judgment of the individual inspector.
    That part of the code is not very high on their priority list, IMO, judging by what I see in all the new construction around here.
    David Banks's Avatar
    David Banks Guest
    Called a "Bollard"
    This is another one of those things around here where you never see it. This is the second call I have received about this from a couple different realtors that refer me but had a listing sell and the same inspector wrote it up. I only know one inspector around here that writes it up. There is not a city around here where the building inspector calls for it.
    I had to agree with the other inspector about some protection needed. It (they) were 18 inches off of the floor and a small curb. I guess I will have to be honest here (I hate myself sometime) I do not write them up if in *MY* opinion they have enough protection. If there is no curb in the garage I do write them up. If the step up is real short I write them up.
    In these cases *MY* opinion says they were not necessary to write up. Step up (curb) and relatively deep.
    Thanks Jim
    I recall we had a discussion on "bollards" a while ago. Check the archives as I'll bet it's there.
    Another choice, the preferred choice in most of South Florida, is to build a masonry block cube platform, 2 feet square by 2 feet high (3 courses) and fill it full of concrete, then set the water heater on it. It is anchored to the slab with rebar to resist lateral movement.
    That raises it higher than the bumper of about anything which will fit in the garage and is much stronger than most bollards you will see.
    If you hit that thing and manage to push it far enough to topple the water heater, you've got a lot more problems than just the water heater. It is like hitting a 2 foot thick concrete wall (because that's what it effectively is).
    It's funny how things vary by area.... here in Oregon we always have bollards in garages in front of furnaces and water heaters but I don't think I've ever seen one outdoors in front of an electric or gas meter.
    Matt,
    Here in Texas we have no bollards in front of water heaters in the garage and we place the gas meters near the street or alley ways so that drivers can easily hit them.
    As far as the meters, it all about convenience of the meter reader to drive down the alley and read the meter from the front seat of the truck.
    My neighbor has backed out and hit her gas meter 3 times in the last 2 yrs.
    The gas company keeps coming out and replacing it or straightening it up.
