Thread: Here's another to identify
08-08-2008, 08:01 PM #1
I took this photo in an attic of an all electric home a couple of weeks ago. It was 130 degrees in the attic and I spent as little time as necessary in the attic but noticed these units and took this photo. The best I can recall they were connected to the all electric HVAC. Haven't determined what they were for...any idea ?
08-09-2008, 10:34 AM #2
08-09-2008, 11:01 AM #3
Re: Here's another to identify
So you don't have to climb a ladder in the attic to set the temp the fans come on.
08-09-2008, 11:30 AM #4
That is not a thermostat, it's a timer called the AirCycler model FR (www.aircycler.com/AirCyclerFR.html).
They are designed to run the air handler blower for a period of time each hour if neither the furnace nor the A/C has kicked in. Usually, the idea is to use the blower to bring in fresh air through a scuttle from the outside to meet a ventilation guideline such as ASHRAE 62.2 in tight houses. We can't tell what these AirCyclers are controlling in this particular application.
Last edited by Edward R. Voytovich; 08-09-2008 at 11:32 AM. Reason: Needed to clarify
08-09-2008, 07:59 PM #5
( www.aircycler.com/AirCyclerFR.html )
Need to leave a space at each end of it for it to work.
08-09-2008, 08:09 PM #6
Looks like the ComboStat. (underlining is mine)
INSTALLING YOUR AirCycler STATThe AirCycler STAT should be installed in a"
central location away from any direct airflow
from air vents.
The other ones state: (underlining is mine)
INSTALLING YOUR AirCyclerThe AirCycler’s unobtrusive design"
allows you to install it anywhere in your
home. It can be installed near a
thermostat, for example, or out of view
near the air handler unit.
I see NOTHING in there about installing it OUTSIDE the home (i.e., "in the attic"). Thus it is not installed in accordance with its installation instructions.
08-11-2008, 04:16 PM #7
Man I like the netting on the walls to hold the insulation in place. Never see that here. Find insulation falling out all the time. It should be a requirement everywhere.
