    Apr 2008
    McKinney Texas
    Default Here's another to identify
    I took this photo in an attic of an all electric home a couple of weeks ago. It was 130 degrees in the attic and I spent as little time as necessary in the attic but noticed these units and took this photo. The best I can recall they were connected to the all electric HVAC. Haven't determined what they were for...any idea ?
    Vancouver - Canada
    Default Re: Here's another to identify
    They're thermostats likely connected to mechanical ventilators to force or enable better air movement and cool attic.
    So you don't have to climb a ladder in the attic to set the temp the fans come on.
    Edward R. Voytovich's Avatar
    Edward R. Voytovich Guest
    That is not a thermostat, it's a timer called the AirCycler model FR (www.aircycler.com/AirCyclerFR.html).
    They are designed to run the air handler blower for a period of time each hour if neither the furnace nor the A/C has kicked in. Usually, the idea is to use the blower to bring in fresh air through a scuttle from the outside to meet a ventilation guideline such as ASHRAE 62.2 in tight houses. We can't tell what these AirCyclers are controlling in this particular application.
    Last edited by Edward R. Voytovich; 08-09-2008 at 11:32 AM. Reason: Needed to clarify
    ( www.aircycler.com/AirCyclerFR.html )
    Need to leave a space at each end of it for it to work.
    Looks like the ComboStat. (underlining is mine)
    INSTALLING YOUR AirCycler STAT
    The AirCycler STAT should be installed in a
    central location away from any direct airflow
    from air vents.
    The other ones state: (underlining is mine)
    The AirCycler’s unobtrusive design
    allows you to install it anywhere in your
    home. It can be installed near a
    thermostat, for example, or out of view
    near the air handler unit.
    I see NOTHING in there about installing it OUTSIDE the home (i.e., "in the attic"). Thus it is not installed in accordance with its installation instructions.
    Fuquay Varina, NC
    Man I like the netting on the walls to hold the insulation in place. Never see that here. Find insulation falling out all the time. It should be a requirement everywhere.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
