Results 1 to 4 of 4
    Jonathan Cartwright's Avatar
    Jonathan Cartwright Guest
    Talking Proper type of gas piping for satellite?
    Is there a specific type of gas piping required for natural gas powered satellite TV equipment?
    Do you get better reception with natural gas or propane?
    Have a great day!
    Default Re: Proper type of gas piping for satellite?
    You haven't seen those before?
    Those are those special "FlameThrower" Alien Defense System Output Stations camouflaged to look like satellite dishes so as to not attract their attention.
    Joe Asta's Avatar
    Joe Asta Guest
    Double check the Model Number before converting to propane. IF it starts with WEBER or CHAR-BROIL then propane is OK, if it starts with Dish or DIrect TV I wouldn't touch it.
    Aren't those disconnected RG58U cables a fire hazard? or have they been properly capped off from the gas line.
    Quote Originally Posted by Joe Asta View Post
    Self-extinguishing ends which close off when pulled out.
    Similar to those found in fuel hoses used as gas stations, only in a much smaller version.
