Thread: Thermostat location
10-14-2008, 11:34 AM #1
Thermostat location
Does anybody know of any codes in the IRC that state prohibited locations for a furnace thermostat. I found a thermostat in a Utility Room 3'-0" away from the furnace. Need a code refference.
10-14-2008, 01:09 PM #2
Re: Thermostat location
I don't known about the code. but the placement is key to the operation of the system.
Best
Ron
10-14-2008, 02:04 PM #3
This would be something that the manufacturer would address in their install guidelines, I have never seen it covered in a code.
For the thermostat to work properly you would need to have an air supply and return in the room, and then this would cause another issue.
I would not worry about a code. I would report that this is a bad location for the thermostat to work properly and that it should be relocated to a central area in the home or as required by the manufacturer of the system.
