    Jon mackay's Avatar
    Jon mackay Guest
    Default Storm window at interior
    I came across an older house that had almost all new windows. One of the windows that was not new had a storm window at the interior wich prevented the window from opening.
    This is a first for me and I was wondering how others would report it.
    David Banks's Avatar
    David Banks Guest
    Default Re: Storm window at interior
    Definite egress issue.
    Richard Stanley's Avatar
    Richard Stanley Guest
    Egress issue IF it is the only window in a bedroom with only 1 door. Otherwise just a defective window operation.
    In need of repair, water entry is likely. The window does not open, so it is not functioning as intended.
    Double whammy (technical term) if it is a window needed for egress from a bedroom.
    Triple whammy ...
    No natural ventilation as required either.
    By the way, the 'two doors' does not solve the problem either - there needs to be two 'paths' (means of egress) in opposite directions. Two doors, opening into one hallway, going to the down stairs does not fulfill that requirement (option).
    Corpus Christi, TX
    Okay, my English as a third language issue is rearing its head again. 'splain to me please, the issue of a door to the outside in a sleeping area not sufficing for emergency egress. Thanks.
    - Paul Fix
    Quote Originally Posted by Thom Walker View Post
    'Cause that's not what was said.
    This is what was said: "Egress issue IF it is the only window in a bedroom with only 1 door."
    Nothing in there about "door" + "to" + "outdoors/outside".
    Just "1 door". There could be 2 doors, neither leading directly to the outdoors.
    Capice? (speelin'?)
    Corpus Christi, TX
    Capiche (sp?)
    - Paul Fix
