Thread: Gasoline Dispenser
02-09-2009, 02:47 PM #1
Gasoline Dispenser
I was inspecting another home. 10 feet from the side of the garage is a gasoline dispenser sitting over an underground tank. It is fed with NM cable direct buried. Other then the NM cable being a violation( it has been this was for 30 years) is the dispenser required to follow article 514?
02-09-2009, 04:36 PM #2
Re: Gasoline Dispenser
Yes for any changes, repairs or alterations if existing. It meets the definition of Motor Fuel Dispensing Facility.
02-09-2009, 04:41 PM #3
Yup--It is pretty amazing what you may find. I made them disconnect and remove the pump before authorizing a meter installation for a re-energize.. It is probably now installed again but I don't have to look at it. I just put another red pin on the map for FD training sites in the county.
