    Capistrano Beach, CA
    Post Celebrity renovator Mikes Holmes to open home inspection business - The Canadian Pres
    InspectionNews has just found the following information that might be of interest to you:
    The Canadian Press, TORONTO
    TORONTO Celebrity renovator Mike Holmes is launching his own home inspection business. The beefy contractor, known for unearthing renovation horror stories on the defunct HGTV series "Holmes on Homes," will launch Mike Holmes Inspections in the ...
    More...
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Celebrity renovator Mikes Holmes to open home inspection business - The Canadian
    Mike Holmes new Home Inspection Website
    Make It Rightâ„¢ | The Holmes Group
    Check out the prices.
    No mention of which SOP his inspectors will work to.
    This should shake up the status quo of the associations of record in Ontario.
    its not going to be pretty. Mike is going to try to turn a home inspection into something it was never to be.
    He is in it for the money just like everyone else along with his past tv series and new shows coming up.
    Mike is a good man and does do a lot of good. But my belief is that he could never stick to a home inspection. He is out to correct the world with his "I know absolutely everything mind fusion" He will be one that will go behind every inspector everywhere and tell the world of their ignorance, lousy work ethics and their pathetic limited knowledge of construction and home inspection.
    JMHO
    You could be right. Time will tell.
    Personally speaking I think the pricing is out of whack with the rest of the industry as is the use of IR and up charge for older homes.
