Results 1 to 13 of 13
Thread: Drain and vent installation
03-05-2009, 10:30 PM #1
This is the first time I have seen something like this. It appears the drain line is on the right and the vent on the left. On the back of this wall is another sink with an air intake valve. I think the vent on the sink connects to the intake valve on the opposing wall. Is this acceptable?
Thx
Mat
03-05-2009, 10:33 PM #2
Re: Drain and vent installation
Forget the photos, it's late
03-05-2009, 10:59 PM #3
03-06-2009, 10:03 AM #4
a true git er done,hack job at best. refer to a plumbing contractor for repairs.
03-10-2009, 12:36 PM #5
Mat,
That drain piping is totally wrong. First off, ABS and PVC pipe cannot be glued together, even if the 'rain or shine' (blue) glue is used, lol. This looks like a feeble attempt to create an 'indirect' drain. If there is a drain on the other side of the wall with an approved vent, these sinks could be plumbed in using a 'cross' fitting and a single vent. Of course 2 approved 'p-traps' would have to be used, (one at each sink tailpiece).
03-17-2009, 09:21 AM #6
The plumber's response was the drain on the left of the photo is used to prime a trap in the laundry room and the sink drain is vented through the roof. No rebuttal for the ABS and PVC glued together.
03-18-2009, 07:07 AM #7
The 'plumber' said that? not an acceptable response.
Double trap as now described
Incorrect trap priming with unsanitary method
S traps
Upside down use of a fitting
Vent fittings where sanitary fittings should be used.
No cleanout
Intermediate reduction in trade size
Too much wrong especially with the introduction of a washing machine somewhere.
Network with a different plumber.
03-19-2009, 07:05 AM #8
Take a look at this.
03-19-2009, 07:48 AM #9
Mat,
That is showing a typical floor drain trap primer installed off the tailpiece.
That is completely different than the installation shown in those photos above.
Those trap primer adapter tailpieces have about a 1/2" to 3/4" tap coming off them and are made for that purpose.
His set up is just plain screwy.
03-19-2009, 09:00 AM #10
No problem.
The food goes down the sink drain and into the washing machine trap and blocks it up nicely. Then of course when the washer trap is dry then the washer connection will have the sink to vent thru. Then you have the sink for the washer to back up into so it does not overflow onto the floor in the laundry room. Like I said, no problem
03-19-2009, 11:03 AM #11
agree with ted. afterall an inspector showed him how to do it and said it was o.k. hope nobody tells this clown it's o.k. to eat glass!
03-19-2009, 11:50 AM #12
This is what he was trying to do:
http://www.jrsmith.com/products/floo...ttal/d2698.pdf
http://www.jrsmith.com/Products/clos...r_trp_prmr.pdf
http://www.jb-products.com/pdfs/brass_41-46.pdf (see page 3, 'trap primer tailpieces' at bottom of page)
03-23-2009, 07:13 AM #13
You should submit them photos to the "Pig slop" thread here The 2009 pig slop contest begins - Terry Love's Plumbing & Remodel DIY forum along with the pdf
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
