Thread: Floor Jacks
    Stephen G Sheldon's Avatar
    Stephen G Sheldon Guest
    Default Floor Jacks
    What is considered a proper method for suppporting floor jackson the ground? On a recent inspection I encountered what is captured in the attached photo.
    Thanks.
    Default Re: Floor Jacks
    Depends on what they are supporting. That one looks like it's right next to the main support pier. Why? What is it supporting.
    By rights any support post should be set on a proper footing but like I said
    That was my thought too.
    Not 'how should the jack be supported' but 'why is that jack even there, that close to a supporting pier'.
    No footing is required for that jack, because it is a temporary jack. It is not intended to be, nor should it be left in place.Like others have pointed out, why was it put there at all.
    It could be a girder intersection that is missing the pier, I don't know, we can't see that part, but if a support is needed it should have an appropriate footing as well.
    Clarksville Home Inspection
    JW Goad
    Hey Steve, What comes first? The pier or the post?
