Results 1 to 12 of 12
05-30-2009, 10:30 PM #1
Almost didnt get in this panel to see this...
05-31-2009, 08:40 AM #2
Re: Almost didnt get in this panel to see this...
Oh My Goodness,
Guess they got tired of the fuses blowing.
at least they used electrical tape
05-31-2009, 09:05 AM #3
John,
I was referring to the wire pieces jumping between poles of the fuse and not the tape alone. The tape seems to be holding the wire jumper to the fuse.
05-31-2009, 09:11 AM #4
maybe they figure if it overloads it willl arc at the ends of the jumper wire, thereby blowing it away and eliminating the connection...................................or, they're just not real bright
05-31-2009, 03:28 PM #5
Look at the bright side. The wire will burn in two before the pieces of copper pipe I usually see used in place of the fuses.
05-31-2009, 09:48 PM #6
I forgot to mention that this was an electricians house.
06-01-2009, 08:23 AM #7
06-01-2009, 08:35 AM #8
Looks ok to me. At least they used stranded wire
06-01-2009, 07:00 PM #9
As the old saying goes:
An eletricians house pops fuses
A plumbers house has leaking pipes
An asbestos workers house is all dusty ....
06-01-2009, 07:46 PM #10
Well as HI's, then, what does that say about our HOUSES?
I probably should move...
06-02-2009, 05:38 AM #11
06-02-2009, 06:34 AM #12
