Thread: Deck flashing
07-12-2009, 03:46 PM #1
Deck flashing
What do you guys think of useing a weather shield type prodcut as flashing between the house and deck?
07-12-2009, 04:01 PM #2
07-12-2009, 04:09 PM #3
07-12-2009, 04:37 PM #4
Re: Deck flashing
From Billy's referenceSIDING AND FLASHING: House siding, or the exterior finish system, must be removed prior to the
installation of the ledger board. Flashing is required at any ledger board connection to a wall of wood
framed construction and shall be composed of copper (attached using copper
nails), stainless steel, UV resistant plastic or galvanized steel coated with 1.85
oz/sf of zinc (G-185 coating). See FIGURE 14 for continuous flashing with drip
edge. The threshold shall be carefully flashed and caulked to prevent water
intrusion due to splashing from the deck or melting snow and ice.
07-12-2009, 04:51 PM #5
Re: Deck flashing
Thanks guys, Thanks for the nap Billy. I owe you one!
07-12-2009, 04:58 PM #6
07-12-2009, 05:55 PM #7
Re: Deck flashing
Thanks BUD, good one! mabey tonite I should be calling you BUD WISER
Or was that why I could'nt find the code reference? Hmmmm, I wonder?
Respectfully, George Thorogood
