Results 1 to 42 of 42
07-29-2009, 07:10 PM #1
These don't look like carpenter ants
First of all as I just posted elsewhere, I only speak in general terms with insects and defer to the experts for ID. I wonder if these are what Ron would call 'nuisance' ants. The realtor gave us the heads-up, a pest control company was going in to treat for ants. I saw the little pile of debris first, in the crawlspace near the sill plate. No sawdust. Then when I pulled the insulation back, they came out running, some with eggs in their beaks. I put the insulation back, don't want them to hide somewhere else. I'm including a pic of the outside wall and it's easy to see why they moved in there. I did not see any other insect signs, no sawdust piles or termite tubes, no rotting wood. These look like the kind that usually tunnel in the dirt, pretty harmless, I think?
07-29-2009, 07:18 PM #2
Re: These don't look like carpenter ants
Of course not, it's lunch time and they took off their tool belts.
Sorry, but you set that one up so well I could not let it pass by.
07-29-2009, 07:26 PM #3
Camponotus modoc. AKA Carpenter ant.
Best
Ron
07-29-2009, 07:42 PM #4
Thanks, Ron. That's why I try not to name them. Once there's damage, it gets easier.
Jerry, these are the architects and planners, no tools.
07-30-2009, 02:09 AM #5
Once again, from those photos, no positive identification can be made. Anyone who says otherwise is mistaken, unless of course, that long-distance ID is made by microscopus inspectoreye, closely related to leftcoastimus hotairius, commonly known as RB.
07-30-2009, 05:26 AM #6
Say BAGDAD BOB
there is only one ant in the Northwest that is a 1/2 inch. long and black and makes a nest in homes
. I Wounder what it could be
Ive got $ 500.00 say thats what it is. Let get John to go get one and take to the local AGG. DEPT.
I have lived and work that part of the Northwest for years as a State LIC. WDO. The ID Is correct.
Best
Ron
07-30-2009, 07:19 AM #7
Looks like a carpenter ant to me.
Nuisance ants, aka. Piss ants, Sugar ants, Pharaoh ants and I'm sure a few more are what come to mind.
07-30-2009, 08:52 AM #8
RB: Here's what the experts say:
“Identifying Common Structure-Infesting Ants
Most of the common species of structure-infesting ants are not difficult to identify after some practice, but the use of a hand lens or microscope is usually necessary to identify species.â€
-Handbook of Pest Control, Arnold Mallis
“Identifying Ants
Magnifiers and Vials
Because ants are so small it is important to have a portable 30X magnifier available at all times.â€
Field Guide for the Management of Structure-Infesting Ants, Stoy A. Hedges, PCT
But then, you probably can identify a carpenter ant on a house using Google Earth, right?
I'll let you keep your $500.
07-30-2009, 09:00 AM #9
Originally Posted by [B
DudeI'm an Expert in this field...
Best
Ron
07-30-2009, 09:05 AM #10
07-30-2009, 09:07 AM #11
NO!
Best
Ron
07-30-2009, 09:08 AM #12
07-30-2009, 09:12 AM #13
07-30-2009, 09:12 AM #14
07-30-2009, 09:13 AM #15
07-30-2009, 09:17 AM #16
07-30-2009, 09:19 AM #17
I would rather be inspecting that POS in Cedar Creek than sitting here on my arse. Very slow end of month. Most months go out with a bang. Not this one.
I did help out with a spot treatment yesterday along with a carpenter ant treatment. Now those monster all black carpenter ants you could have identified from google earth. Not to often I see them that big and solid black.
07-30-2009, 09:21 AM #18
07-30-2009, 09:25 AM #19
squirt squirt squirt
RB: Your scooter's sound?
07-30-2009, 10:10 AM #20
Hi,
I'll agree with Ron. Carpenter ants are the largest species in N.A. and especially in this region. The first photo is fuzzy, but even then one can see that the antennae are set far back on the head of those ants, so they'll be out of the way when they're mining wood, and that the top of their thorax is smoothly rounded, sort of like the curve you'd see on the top of a teardrop gas tank on most choppers. Those are two of the three characteristics needed to identify a carpenter ant; the other, the one that I can't make out from the photo, is the petiole node - I can't tell if there is one there and if there is there should be only one.
Just because you didn't find frass doesn't mean they aren't carpenter ants; carpenter ants have no reason to mine wood and create frass, as long as the place they've chosen to store their eggs is large enough for their purposes. They create the frass when they begin enlarging their domain. Unlike termites, which live in their own filth, carpenter ants are fastidious and will dump all frass and other detritus outside.
They also might not be "nesting" in the home but instead are using it for an incubator. Around here - not much more than 100 miles from V.I. - they'll nest outside in rotting wood or railroad ties used for landscaping timbers and will move their eggs to dry storage in the walls of houses, typically on the south side where the wall will be nice and warm.
Putting the insulation back probably did nothing to prevent them from moving; once they think they've been discovered, they'll put every single drone to work ferrying those eggs to a new location so that when the pest guy arrives he might not see anything there.
Don't look for the nest in an obvious straight line from where you found them; I've followed them out of a crawlspace wall, up the side of a house, into the attic, out the other side of the attic, down the other side of the house and across a lawn to railroad ties where I found the main nest. Total distance - probably 200ft. - actual distance from the nursery - 60ft.
A couple of weeks ago, I came across a house with a steady train of camponotus carrying bits of insects up the corner of a chimney and into a gap between the roof deck and the chimneystack, while at the same time another train came down and about every tenth ant coming down the stack carried an egg. It was pretty obvious that there was a queen up there someplace churning out eggs and the eggs were being moved to the nursery.
ONE TEAM - ONE FIGHT!!!
Mike
07-30-2009, 10:13 AM #21
MOH: Damn! Google Earth has a lot of you ant inspectors running around!
07-30-2009, 11:26 AM #22
They do look like carpenters. Who would like to bet they are not?
07-30-2009, 11:46 AM #23
07-30-2009, 01:17 PM #24
07-30-2009, 02:52 PM #25
07-30-2009, 03:26 PM #26
07-30-2009, 03:41 PM #27
Ron,
How did you capture that image from Google?
Curious Rick
07-30-2009, 03:45 PM #28
07-30-2009, 04:13 PM #29
07-30-2009, 06:58 PM #30
07-30-2009, 09:20 PM #31
07-30-2009, 10:13 PM #32
Pest Control Canada
And thank you, Micheal P. O'Handley, that's good info.
07-31-2009, 05:07 AM #33
Rick, To capture your screen, bring up the image, hit the print screen key, then open the paint program under acessories, click on edit, then click paste.
Or instead of paint i use IrfanView - Official Homepage - one of the most popular viewers worldwide
08-01-2009, 09:01 AM #34
08-03-2009, 12:00 AM #35
Yeah,
if you go out very late at night with a flashlight and make a circle around that stump you should find a trail being tended by workers; kind of like the VC would come out at night and repair the wagon track known as the Ho Chi Minh trail, after daytime efforts to destroy it, in Vietnam during the war. The trail will lead from that stump to another location, possibly the house.
Mike
08-03-2009, 04:57 AM #36
08-03-2009, 11:30 AM #37
08-03-2009, 01:55 PM #38
Termidor
The only way to go
08-03-2009, 02:52 PM #39
08-03-2009, 06:16 PM #40
If you want to deal with carpenter ants. use a vacuum cleaner
I'm not joking...If you can find the mass nest in a home a vacuum cleaner works great. BIG GIANT SUCKING SOUND
And they will not come back...
Yeah, if you want to tear open the house to get to them. I found 6 separates nests on my half acre property, a few of which were inside my home. I inspected the house before I bought it, and did find evidence of the ants, but did not expect what I had found. I used the Termidor last year, and haven't seen an ant willing to step foot onto by structure since...I'm still watching 2 separate nests on my property for fun. One of them is in my barkdust, and another one is in a detached structure. I hate to kill them off as my blue jay population is growing, and I hate to take away a food source.
08-06-2009, 03:38 PM #41
08-07-2009, 02:32 AM #42
If you hold down the "Alt" button then hit "PrintScrn"
then it will copy only your highlighted
(the window on top) window.
