    Default Moleruns (Mole Runs) Recomendation
    Roof is currently watertight, but entire surface has numerous mole runs.
    Ignoring the other problems, would you recommend replacement?
    Default Re: Moleruns (Mole Runs) Recommendation
    Roof is currently watertight, but entire surface numerous mole runs.
    Never heard that term before. You may need to use poison peanuts as a first treatment.
    Always called them "wrinkles", or "blisters", or "fish-mouths" depending on how big they were.
    Yep. and properly slope the deck too, requires a minimum 1/4" per foot slope.
    Hum.... checking.... it's in wiki:
    mole run - Wiktionary
    and the Wayne Roofing disctionary as well:
    Roofing Glossary
    Default Re: Moleruns (Mole Runs) Recomendation
    However Jerry's is always the "conservative" recommendation, anyone else?
    That's mighty wrinkly. I'd recommend replacement, too.
    Ron Bibler's Avatar
    Ron Bibler Guest
    I would like to see that roof under Infrared
    Best
    Ron
    [quote=Ron Bibler;96563]I would like to see that roof under Infrared/quote]
    Actully, I'm going to try to get back out there very early morning after the deal closes, - not much to see topside after 5 hours in direct sun.
    No water at the underside, either, though there was a classic missing insulation image, and lots of "quality" ductwork.
    Ron Bibler's Avatar
    Ron Bibler Guest
    quote] Actully, I'm going to try to get back out there very early morning after the deal closes, - not much to see topside after 5 hours in direct sun.[/quote]
    Can you say that another way ? I can't understand what you are trying to say. thanks.
    If you are saying what i think you are trying to say dang...
    You should go up on the roof just after sunset a keep a Thermal eye on the roof for thing to come alive for you.
    Best
    Ron
