Thread: dryer closet vented to outdoors?
08-21-2009, 01:07 PM #1
So I'm researching for another question I posted about gas dryer installation, and I ran into this from a GE installation manual:
"ALCOVE OR CLOSET INSTALLATION" ...
"The closet should be vented to the outdoors to prevent gas pocketing in case of a gas leak in the supply line."
Say what? Has anyone seen a laundry closet vented to the outdoors? I sure haven't.
Similar Threads:"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961)
08-21-2009, 01:10 PM #2
Re: dryer closet vented to outdoors?
08-21-2009, 01:17 PM #3
Well, in the same section about closet installation, it says the dryer must be vented to the outdoors, and the closet must be vented to the outdoors. So I assume the dryer vent doesn't count.
If the closet venting is in case of a gas leak, the dryer vent would likely only help while the dryer is running, yes?
08-21-2009, 01:48 PM #4
Here's another thing I'm having trouble wrapping what's left of my mind around - from the same gas dryer installation manual:
"Closet doors must be louvered or otherwise ventilated and
must contain a minimum of 60 sq. in. of open area equally
distributed. If the closet contains both a washer and a
dryer, doors must contain a minimum of 120 sq. in. of open
area equally distributed."
What difference does it make if there's a washer?
08-21-2009, 03:15 PM #5
