Thread: Another panel question
09-08-2009, 06:57 AM #1
The house was built in 1903, obviously changes were made. This is the service disconnect with a 100amp. The neutrals and grounds are on the same bar, but I could not find an equipement ground. Needed some more eyes
09-08-2009, 07:04 AM #2
Re: Another panel question
The grounds that are on the same bar as the neutrals are equipment grounds. Do you mean you didn't see a grounding electrode conductor?
09-08-2009, 07:22 AM #3
Looks like the GEC is to the left of the PVC conduits. It also looks like you can see where it bends just to the left of the bottom left breaker.
If you are looking for grounding conductors for wiring run in 1903 it will take awhile. That would pre-date grounded circuits.
09-08-2009, 07:32 AM #4
Should have proof read that, yes the GEC. But the house was rewired.
09-08-2009, 08:21 AM #5
This is what Jim pointed out.
09-08-2009, 08:42 AM #6
Thanks David, exactly what I saw.
How did you insert those arrows?
09-08-2009, 09:26 AM #7
I got it here.
Home Whisper Image Edit Light
