Thread: gas fireplace chimney placement
09-09-2009, 02:07 PM #1
Ok, i have a home with a gas fireplace that has blowers, and remote and appears to be installed correctly. you know what that means..it isn't.
Anyway, the exterior vent stack is located on a side wall that is actually below a underhang of a front porch roof, it did not go up through the roof. The siding is vinyl as are the soffits. i don't know how to post a picture. but i really am not liking this installation. The owner was there and said that he didn't go up through the roof because all the main support beams were in that area. Now i have seen other fireplace vents comming out of the side of a home but not with any over hang above them. any help here?
09-09-2009, 04:06 PM #2
Re: gas fireplace chimney placement
Call a chimney pro and have him come out and tell the owner what is required. If there is no room to go through the soffit then you must go around but cannot stay where it is if I am Picturing what your picture would have pictured
Or are you talking about a direct vent?
09-09-2009, 04:08 PM #3
Get the make, model and serial number. With that, get the correct copy of the listed instructions, which will show the approved vent termination clearances including to ventilated and unventilated soffits and to plastic soffits.
HTH,
Bob
FWIW, Heatilator is made right down in Mt. Pleasant, Ia. If you call ahead, you may be able to take a plant tour.
