Thread: Ground on service panel
09-21-2009, 01:21 PM #1
Are you allowed to ground tv equipment on a service panel?
09-21-2009, 02:40 PM #2
Re: Ground on service panel
Ryan,
Did you take a photo closer up and viewing from the bottom up to it?
It is required to be grounded to the grounding electrode system.
Also, that whatever-it-is-ground-fitting looks like it will interfere with the opening of that door.
09-21-2009, 03:34 PM #3
No, I did not. But that opening is how you access the service conductors. I was able to open and close without much difficulty. The ground is for the cable tv as far as I can tell.
09-21-2009, 03:39 PM #4
09-21-2009, 03:42 PM #5
Gunnar, thanks.
09-21-2009, 04:28 PM #6
09-21-2009, 05:01 PM #7
09-21-2009, 05:05 PM #8
09-21-2009, 05:39 PM #9
JP,
I think it was just similar to the "last man in" theory. I said it last, therefor I said it.
