Thread: Service box melting
09-21-2009, 03:28 PM #1
Service box melting
Has anyone seen breakers and other parts of a service panel that look like they have been slightly melted or burned.
Thanks,
Ryan
09-21-2009, 03:33 PM #2
Re: Service box melting
Wow, something's not right. Looks like a Square D panel. Probably arcing at a circuit breaker connection. Might be able to purchase new guts and replace those.
09-21-2009, 03:36 PM #3
Yeah, I don't know what the heck is going on with it.
09-21-2009, 04:26 PM #4
Someone accidentally hit that main bus bar with a wire which should not have touched it.
I'll bet that lead to some sparks and fireworks, and possibly even to someone having to change their pants afterward.
I'm guessing that the VERY HIGH CURRENT DRAW which it took to make those arc marks are what overheated that one bus and melted that plastic.
That interior panelboard NEEDS TO BE REPLACED. Chances are it can be replaced easily as it is a Square D and they should be able to find a matching replacement, or at least a matching interior panelboard which is listed with that enclosure.
09-21-2009, 05:16 PM #5
Now THAT is an overheated panel.
That was not caused by a fault or spark. That was a long term overheating, not a quick jolt.
I call loose connection at the top of the buss.
09-21-2009, 05:19 PM #6
Peter,
And that serious arcing, melting, burning of the top of the bus bar without discoloring the bolted connection?
09-21-2009, 05:28 PM #7
That to me looks like SERIOUS overheating. I don't see that as an arc. Looks like the plating has flaked off from the extreme heat.
A clearer pic would tell the tale though.
09-21-2009, 05:38 PM #8
