Thread: peppermint test
    Jun 2008
    Default peppermint test
    I was talking to a person the other day about an odor they have in their house. It is a slab on grade. They've had several plumbers out and one of them recommended a peppermint test to check for hidden leaks.
    I had never heard of this method of testing for leaks. Do any of you have experience with it? How effective is it?
    Testing water supply and more plumbing
    Default Re: peppermint test
    Chasing odors in waste lines is hard no matter what type of test you do. I have heard of the peppermint test and I have witnessed smoke testing. My town even did smoke testing of the sewers not long ago. That was a sight seeing homes vent pipes smoking!
    I would think that if you can't find an odor that is already present then you won't be able to find a peppermint odor either.
    Cool Re: peppermint test
    Don't you know you aren't suppose to eat the mints from the bathroom?
    They need a pipe camera to scope for breaches in the pipes. If they really have to, they can have a plumber use test balls and pressurize the system for leaks. Won't locate but will prove the DWV line is tight to a degree.
    Bob
    Tony Watson's Avatar
    Tony Watson Guest
    The "Peppermint Test" will tell if the odor is coming from the dwv system or not. Not where the leak is, if there is one.
