Results 1 to 15 of 15
Thread: Loose Toilet?
    Bob Shelton's Avatar
    Bob Shelton Guest
    Chuck Lambert's Avatar
    Chuck Lambert Guest
    Default Re: Loose Toilet?
    Quote Originally Posted by Bob Shelton View Post
    What constitutes a Loose Toilet?
    A toilet that moves when you stradle it grab with your knees and twist.
    Chuck
    Either the between your knees or just nudge it with your knee. If it is loose it will move. If it moves in the slightest it is loose. There is no close to moving. It's loose or it's not. The wax ring seal is now broken if you can move it at all. You cannot just tighten the toilet back down and it's all better. The wax ring does not swell back up. It might not be leaking water but it could be leaking gas.
    Bob, Chuck and Ted are wimps. Ya gotta reach around the bowl, kind a like you are giving it a bear hug! Then if you can move it with your arms and hands it is loose.
    Hope you're up to date on all your shots with that technique Scott. I ain't putting my bare hands on any toilet bowl, including the one in my own house. I use my foot and nudge the bowl. Afterwards, I burn my shoes .
    I just give them a swift kick with the shoe, if it moves it is loose.
    Many times (at least I did) you will find them "move" be not be "loose" ... i.e., the toilet itself is securely attached to the floor flange (not "loose") but the floor flange is not securely attached to the floor (allowing the toilet to "move") - this means the toilet is "loose".
    Montreal, QC, Canada
    Wow - A Toilet that passes gas..........lol
    I usually straddle the bowl between my knees and try to rock it!
    I'm with Scott. Well, I don't really bear-hug the things, but I do use my hands. Hey, that's what an immune system is for! Use it or lose it!
    Apr 2007
    state of jefferson
    one that flushes on the first date
    LOL!!
    Always a comodian in every crowd.
    rick
    I lift the lid, grab the rim bare handed enjoying the cool porceline while anchoring my fingers in the holes that fill the toilet with water and give it a pull side to side. If it moves it is loose!
    Michael Carson
    Inspect It Right Home Inspections L.L.C.
    www.inspectitrighthomeinspection.com
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Jim, an immune system won't defend against body lice!
    Dave Gilstrap's Avatar
    Dave Gilstrap Guest
    Smile Re: Loose Toilet?
    I straddle the toilet with my legs, (standing up of course) and wiggle the toilet an the tank. I call this the toilet dance. If it moves I write it up as loose.
    JORY LANNES's Avatar
    JORY LANNES Guest
    I agree with Joe and Dave.
