    Norm Peery's Avatar
    Norm Peery Guest
    Default Electrical panel & Gas Water Heater
    I thought I might get blown up today. Inspecting a 50 year old house with an exterior closet, 2'X4', housing a gas water heater and an electrical panel. The closet had no vents, and when I opened the door the gas fumes curled my hair, what's left of it.
    I left the door open and got the gas vented out, but my question is.......
    Do the codes allow this? Common sense says no way, and that's what my report says................... but what about code?
    Thanks,
    Norm
    Atlanta, Georgia
    Default Re: Electrical panel & Gas Water Heater
    Do codes allow what? Gas appliance and electrical panel in the same utility closet?
    If you are smelling gas in an enclosed space then there is not sufficent combustion air, a pssible gas leak, or insufficient venting. Sounds like a defect gas appliance installation.
    NEC requires an area 30"x36" of clear access in front of a panel. Considering a 50 gallon water heater in a 2'x4' closet, there is probably not the required clear area in front of the panel.
    Are you asking about the potential explosion hazard of electrical sparks and gas appliance. Nope, no code issues.
    Can you be more specific about what code issues might be a concern?
    Ron Bibler's Avatar
    Ron Bibler Guest
    Glad your ok Norm...
    Best
    Ron
    Quote Originally Posted by Norm Peery View Post
    Thanks,
    Norm
    *Gas fumes?
    *Gas like what is used for a lawnmower or natural gas for the water heater?
    *Was the water heater on a raised platform that was 18" or greater?
    Without the size of the water heater (btu's) it is hard to say if the room is large enough (combustion makeup air), most likely it is not. In a room that size, I'm sure that the electrical panel did not have the proper working clearance in front and on the sides.
    Norm Peery's Avatar
    Norm Peery Guest
    Hi Guys,
    Natural gas fumes were present, none of the required clearances for the water heater or the electrical panel, and no ventilation ports.
    My 1st thought, when I smelled the gas was, could the electrical panel, if enough gas is present, create a hazard.
    Just wondered if the codes ever addressed that situation.
    Thanks for your input.
    Norm
    Norm,
    I'll rephrase that ... the gas water heater created a hazard, the electrical panel was only there to help out.
    Have to keep your priorities in the right order: if that had been an electric water heater, no problem; if that had been a properly installed and operating gas water heater, no problem; therefore it is the improperly installed and lack of maintenance for the water heater which created the hazard.
    Code are minimum and cannot address all stupid possibilities, no.
    Norm Peery's Avatar
    Norm Peery Guest
    Norm
    Many times I have been told "It meets code", and many times I have said, "ya, but does it meet YOUR safety requirements for your family?"
    Norm
