Results 1 to 19 of 19
Thread: HVAC System
02-09-2010, 08:44 AM #1
HVAC System
Do you report when you see uninsulated ducts in areas with no heat.
02-09-2010, 12:38 PM #2
Re: HVAC System
Are these type of ducts allowed anywhere in HVAC, regardless of heated or not heated area?
02-09-2010, 01:30 PM #3
Re: HVAC System
That looks like insulated flex duct! Not sure of your question!
James Bohac
02-09-2010, 03:28 PM #4
Re: HVAC System
It's flex duct but there is no insulation.
02-09-2010, 07:35 PM #5
Re: HVAC System
02-09-2010, 08:35 PM #6
Re: HVAC System
Jerry, there is no insulation. They are very thin. The runs seem pretty short, limited to the closet space.
02-09-2010, 09:11 PM #7
Re: HVAC System
For one thing, they are not supported properly, as to whether they are even allowed to be used there is another concern - would need to have more information, such as the UL number on them, the manufacturer, etc., as they may (or may not) even be allowed to be used in that installation.
If that closet is not within the thermal envelope, then the answer is not allowed, if that closet is withing the thermal envelope ... maybe ... is the best I can do right now - but you can write them up for not being properly installed, and from there have a properly licensed and competent mechanical contractor determine if those uninsulated air connectors are even allowed.
02-09-2010, 10:17 PM #8
Re: HVAC System
Well the thermal envelope is a tricky question. It is a utility closet within the garage and the walls may or may not be insulated. They likely are insulated because there is a bedroom and bathroom above the area. I will get more info off the duct when I return to grab a radon test. Thanks for the help. The installation looked like a bit of hack job to me, but what do I know
02-10-2010, 09:12 AM #9
Re: HVAC System
Looks like the homeowner wanted some extra returns in the house. Complete hack job.
02-10-2010, 04:04 PM #10
Re: HVAC System
Those look like dryer slinkies, not real HVAC flex duct. I don't think it is insulated. Lack of support and poor install are easy write-ups. I'd add verify proper CFM to rooms by HVAC contractor. Those look like maybe 4", which isn't going to sufficiently supply anything beyond a bathroom. Don't see a bypass on that HUM either.
02-10-2010, 07:06 PM #11
Re: HVAC System
02-11-2010, 01:12 PM #12
Re: HVAC System
Well, JP you ought to clarify you are allowed to use flexible 'transition ducts' on dryer vents if using the prescribed materials under the prescribed conditions but............
Somebody tell me how you use a flexible transition duct and maintain a male-up pipe orientation? I've never seen a flex hose that was sized to slip inside a rigid pipe that didn't downsize the duct.
02-11-2010, 01:37 PM #13
Re: HVAC System
02-12-2010, 12:00 PM #14
Re: HVAC System
Are you sure those are heat ducts and not return air ducts?
02-12-2010, 12:20 PM #15
Re: HVAC System
A contractor evaluated it and said it was fine, just cheap. I asked him about the duct sized and lack of insulation and he could have cared less. Then the buyer was there and asked how much to improve it and he said 1000 to 1500. Glad I said something about it, I don't want to pay for it
02-12-2010, 06:25 PM #16
Re: HVAC System
03-11-2010, 10:13 AM #17
Re: HVAC System
What state is that in? In CA code is a minimum R-4.2. As far as that furnace being in the envelope, it doesn't appear to be. I'm not sure what contractor would say that was O.K. If you measured the external static pressure (ESP) I'm sure it would be far outside the capability of the blower. Just a drastic loss in capacity for the system, but hey, if the home owner wants to run a 5 ton A/C to get 4 tons of cooling, good for him.
03-15-2010, 08:09 AM #18
Re: HVAC System
If the installation is in an unheated space you better check the water piping and water softener too.
04-04-2010, 10:31 AM #19
Re: HVAC System
There is also a loss in thermal efficiency here. In New Jersey all branch ducts in new construction must be minimum of R-6
