    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Vent fan over bahtub ?
    Check out this ventfan/light set up... This bathroom has a step in bathtub/shower with a ventfan/light. The ventfan/light can drop down for service or repairs.
    My question is. Is this set OK. As the ventfan/light could fall open due rust of the metal parts inside and expose the wires to someone in the bathtub/shower.
    Any input please.
    Best
    Ron
    Default Re: Vent fan over bahtub ?
    I see Broan makes a similar looking fan that is UL liste for use over a tub/shower when used with a GFCI.
    Default Re: Vent fan over bathtub ?
    Yes, no, maybe ... see Jim's post above.
    You would need to remove the bottom cover/light lens and see what it is rated for, and, yes, it would need to be GFCI protected.
    A.D. Miller's Avatar
    A.D. Miller Guest
    Many units are UL listed for this use if GFCI protected.
