05-10-2010, 09:21 AM #1
condensate drains through bsmt floor
Can someone remind me why they do this?
New construction. No basement perimeter drain or sump pump.
Similar Threads:"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961)
05-10-2010, 09:36 AM #2
Re: condensate drains through bsmt floor
Oh, yeah. And why would this flex drain line be here in a basement corner? Propane vent? I almost never see propane, but I'm thinking that's what it is. It's quite far from the furnace and water heater.
05-10-2010, 10:05 AM #3
Pic #1 - because they are stupid, cheap or figured no one would notice.
There's no real way to verify where it goes. A condensate pump, a couple clamps and tubing will run $50-60. Not exactly a big expense to do the job better.
Pic #2 - who knows, if it wasn't so vertical I might think a cheap perimeter drain tube that never got attached to a sump pit that wasn't installed. That's one of those great reasons to have a seesnake along.
05-10-2010, 10:58 AM #4
John, I agree with Markus on #1. It's just a cheap way of doing it.
As for the black flexible pipe in the floor, maybe a rough-in for a radon mitigation system? Although I've never seen that type of piping used for a radon rough-in.
05-10-2010, 11:20 AM #5
05-10-2010, 12:07 PM #6
Pic #1 - condensate drain in floor.
The argument I get from contractors who install the drain under the floor insist it is a better alternative to a condensate pump. "Gravity feed, no power requirement, the green solution".
