Results 1 to 2 of 2
    brianmiller's Avatar
    brianmiller Guest
    Default Condensate drain line/Furnace Vent
    I was searching in the 2006 IRC for codes that indicate that the primary drain line is required to be insuated and for furnace elbows to be strapped, but I couldn't find the code reference.
    Does anyone know what the IRC reference are?
    thanks,
    Brian
    Default Re: Condensate drain line/Furnace Vent
    thanks,
    Brian
    As far as the drain line, I do not think it is addressed. Try the manufacturers installation requirements.
    I assume you are talking about the furnace flue pipe being supported?
    Try 2427.10.10 in the IRC, I think this is the section that covers what you are asking. Also the vent pipe manufacturer might have specific requirements.
