    mathew stouffer's Avatar
    mathew stouffer Guest
    Default 6 Air Handlers 3 Condensers
    I had a post similar to this a few months ago but this system was pretty interesting, so I thought I would get your thoughts. 9000 ft home, built in 08. It had 6 air handles operating off 3 condensers, approx two 3 ton units and one 4 ton. System worked pretty well, but one HVAC guy I spoke to said no way. Tried to contact Trane but no luck yet.
    Default Re: 6 Air Handlers 3 Condensers
    Is this acceptable?
    David Bell's Avatar
    David Bell Guest
    These systems can be operated useing solenoid valves on the liquid lines, and preferably a two stage compressor.
    Those high-end Trane 19i units have 2 stage compressors.
    Utah
    I have seen these several times but I think the key point is your comment "System worked pretty well . . ." and (my add) has apparently worked well for two summers.
    I have also designed several larger commercial systems where a single circuit compressor will serve two coils but in the same air handler. A little different situation I know.
    You get to see some pretty interesting homes in the high valley don't you?
