    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Air Sampling Pump
    Anyone testing for mold these days. I finally had to break down and buy a pump. What are some good ones you have used?
    Apr 2007
    WESTMINSTER CO
    Default Re: Air Sampling Pump
    I USE zefon international--from pro labs--and the z-5 samplers
    cvf
    Thanks. How do you structure costs.
    Hello Matt-
    The pump is far less important than the process. One could use the finest equipment on the market, and still produce junk data.
    Performing valid air monitoring for mould typically costs somewhere on the order of $1,500 to $2,500 and those results are good ONLY for that one day during which the samples were collected.
    The costs necessary for performing valid indoor airborne assessments for moulds is just one of the many reasons that such monitoring is virtually never done by legitimate experts in mould and human exposures, and is, at the moment, almost the exclusive prevue of the flim-flam man,
    Cheers!
    CaoimhÃ*n P. Connell
    Forensic Industrial Hygienist
    Forensic Applications Consulting Technologies, Inc. - Home
    (The opinions expressed here are exclusively my personal opinions and do not necessarily reflect my professional opinion, opinion of my employer, agency, peers, or professional affiliates. The above post is for information only and does not reflect professional advice and is not intended to supercede the professional advice of others.)
    AMDG
