Thread: EIFS
    Bruce Hutton's Avatar
    Bruce Hutton Guest
    Default EIFS
    Hi everyone,
    I have an inspection scheduled tomorrow The home is of EIFS construction. I run across 1 of these about every 2 years.
    I am pretty familiar with flashings / sealants etc.
    I refer clients to EIMA - Guide to exterior finish system construction
    when I come across these houses.
    http://www.eima.com/pdfs/EIMA%20CGui...nal_VA_Web.pdf
    I always print out the installation guideline & generally have 1-2 of these in my travel file that I can give to clients at any given time.
    What do you guys do & what guidlines do you go by?
    Are there more stringent guidlines than EIMA.
    I am very nervous about this EIFS...should I be?
    Any help / advice would be greatly apopreciated.
    Thanks in advance!!!!
    Bruce
    Default Re: EIFS
    Quote Originally Posted by Bruce Hutton View Post
    Hi everyone,
    Bruce
    EIMA guidelines are what you should use when the manufacturer is unknown. They are generic but they cover just about everything.
    You should consider deferring the EIFS to another inspector who has more experience with it. There are many types of EIFS and similar looking systems. Just telling your client to look at the EIMA guidelines does not do much for them. I would say that around 98% of the EIFS homes have some type of problem.
    Mahtomedi, Minnesota
    Default Re: EIFS
    If you are being asked to evaluate EIFS and you don't have experience with evaluating EIFS it may be wise to be nervous.
    EIFS seems to be a product that is misunderstood by many installers, contractors and inspectors.
    Do you have moisture testing equipment suitable for testing sheathing behind EIFS? If not, you may be wise to defer the evaluation to another inspector who has EIFS expertise. Maybe one who lives near you and reads this will respond here?
    Fred Comb, ACI
    Mahtomedi, MN
    www.homeinspectionsofmn.com
    ventura, ca
    Default Re: EIFS
    My advice to you is - don't do it.
    Use the opportunity to motivate yourself to become an EIFS expert.
    Many knowledgable inspectors have been motivated by just such circumstances.
    Defer to a fellow inspector and go as a ride along.
    Always listen to you inner voice.....
    How many times have you been driving home from an inspection, and have this
    funny feeling, then as soon as you pull in your driveway, "Oh, I forgot to
    inspect the ..........you can inspect the next EIFS system.
    mf
    Matt Faust
    Real Estate Inspector
    Bruce Hutton Guest
    Default Re: EIFS
    Thanks Guys - You input means alot!
    I dont have the correct equipment to test the EIFS...I havent done one yet that I had not reffered it out to a certified EIFS inspector.
    Our closet guys is about 2 1/2 - 3 hrs away...To the best of my knowledge.
    The last house I inspected that had EIFS had $38,000 in repairs by a certified company & the client ended up buying a moisture warranty.
    I like to have the guide on hand & I can point out a couple of issues with the client & show them why I am reffering it out to a certified EIFS inspector.
    I have only seen this stuff 4-5 times in 7 1/2 years as an inspector.
    Matt...Not to disagree but I just cant find enough motivation with this EIFS to want to be the expert in this field.
    I really dont like this stuff as you can tell!
    I would tend to agree with Scott - 98% have problems...Thats what make me nervous.
    Thanks for your replies guys the help is appreciated!!!!
    Default Re: EIFS
    FYI, by learning about EIFS you will also learn about water infiltration into structures. I can't tell you how much you will learn and how it relates to other cladding's on homes and buildings.
    EDI had one if not the best education programs.
    Apr 2007
    WESTMINSTER CO
    Default Re: EIFS
    hope this helps alittle
    cvf
    Bruce Hutton Guest
    Default Re: EIFS
    Thanks again...Charlie the illustrations are great!
    It is very appreciated!
    BH
    Mar 2009
    Denver
    Default Re: EIFS
    Here are some free tips for inspecting EIFS Stucco/EIFS Inspection Tips - InterNACHI The video is open and free to all.
    And here is the entire online video course Stucco & EIFS Training and Certification Course: - InterNACHI
    Lisa Endza
    Director of Communication
    InterNACHI
