Thread: ranch trusses
    Default ranch trusses
    Simple 4 year old rancher. Not sure what to make of not-so-simple roof framing.
    Could it have anything to do with the fact that the owner works for T. Bros?
    New Mexico
    Default Re: ranch trusses
    I agree. The first pic looked like two trusses designed to be stitched together in the middle, much like a double wide or modular. Any other signs of prefab at the place?
    I've never seen this type of framing but I figured it was some kind of "stitching" situation. Does this actually look kosher?
    As we say in Philadelphia, I don't "know from" prefab.
    Definitely modular construction.
    Modular.
    That's the two halves where they were married together.
    The give away is not only that framing and 'double center', but ... that white plastic hanging from the ridge.
    These are shipped with the open side covered with white plastic, and the remains of it were left stuck in the wedgie section at the ridge.
    Modular
    Joseph P. Hagarty's Avatar
    Joseph P. Hagarty Guest
    Modular.
    Typical of Modular construction.
    Agreed.
    Rob Thomas's Avatar
    Rob Thomas Guest
    The top chord of every truss is hinged. It isn't "typical" of modular construction, it IS modular construction.
    RT
    Quote Originally Posted by Joseph P. Hagarty View Post
    Agreed.
    Colorado Springs, CO
    This may be obvious but the trusses on these modulars are hinged so the finished units will have a steeper roof and not look so much like a modular. The trusses are folded down so the unit will be able to pass under bridges, utility lines, etc. during transport and are raised when the unit is set.
    Bruce Breedlove
    www.avaloninspection.com
