Results 1 to 4 of 4
    David King's Avatar
    David King Guest
    Default Air gap in chimney exterior wall ?
    Hi all,
    My first post in IN. I came across this air gap in a chimney face, just under the chimney cap. Gap was clean and rectangular; looked like it was built this way. There is a flue/liner in the chimney for exhausting the gas water heater.
    Can I assume that this air gap is normal and used for some form of chimney venting ?
    Thanks / Dave
    Default Re: Air gap in chimney exterior wall ?
    I have not seen anything like that ever in a masonry chimney. So I would say it is not normal.
    If I'm looking at what I think I am, it should not be there. That's enough reason to have it checked out to be sure.
    David King's Avatar
    David King Guest
    Raymond / Eric,
    Thanks for your reply. I had already reported "further investigation required".....just wanted to be sure that I was on the right track.
    Photo is taken looking up under the chimney cap...does seem odd that the gap is so uniform.
    Dave
