Thread: Siding material
05-10-2011, 07:56 AM #1
Siding material
siding1a.jpgI am trying to identify a siding material - it looks like T1-11 but is a fibrous material. I want to ID this material so I can get a copy of the installation instructions [web search].
As seen in the photos this has been installed to grade, typically these types of materials require a minimum separation from grade.
Thank you for any assistance you may provide.
05-10-2011, 10:38 AM #2
Re: Siding material
It looks like a MDF (medium density fiberboard) product. The pattern looks like it might be Georgia Pacific. What was the size of the panels or planks?
05-10-2011, 12:55 PM #3
Re: Siding material
That looks like masonite to me.
05-10-2011, 01:11 PM #4
Re: Siding material
05-10-2011, 02:56 PM #5
Re: Siding material
Looks like that old fiberboard garbage we used to put around back porch enclosures. Good luck finding an install manual for that. Whoever made the stuff has probably scoured the web trying to erase any documentation. That stuff just screams 'more water, more water'.
Good luck
05-10-2011, 04:19 PM #6
Re: Siding material
it is definately csf, cheap $he!t fibreboard.
05-10-2011, 04:24 PM #7
Re: Siding material
I found this on a web search for how to install this product:
Light propane torch, touch to siding, if siding is too wet to burn then siding is too wet to remain in place, remove siding and install real siding; if siding is not too wet to burn, allow siding to burn, sweep up ashes, install real siding.
05-11-2011, 09:58 AM #8
Re: Siding material
Thanx for the replies - this material was actually installed about 1 year ago.
05-11-2011, 11:58 AM #9
