Thread: AC coil fins
10-14-2011, 03:25 PM #1
AC coil fins
How do you write up when the exterior coil fins are corroded but the machine is still cooling. Unit is from 2002
10-14-2011, 04:56 PM #2
Re: AC coil fins
That it is not operating properly.
It was designed and intended to transfer a given amount of heat from the coil to the air, and without the proper number, size, and condition fins, that heat transfer is going to be reduced, sometimes *drastically* reduced.
The condenser unit needs to be replaced, which now means replacing the interior unit too.
10-14-2011, 05:10 PM #3
Re: AC coil fins
Thank you much
