Thread: Zero Clearance
    Sep 2008
    so so, California
    Default Zero Clearance
    Would it be safe to assume that because zero clearance boxes are obsolete, and now maintain minimum clearance to combustibles that these boxes are in their current state, a hazard? I have 4 in one house.
    Would it also be safe to assume that because the box is flushed out, that combustibles could possibly be in direct contact with the face?
    Default Re: Zero Clearance
    Good Morning Marc,
    The Posted Labels state to use only The Approved Zero Clearance Spacers.
    * so Zero clearance is from the installed spacer.
    ** other label clearances 8' to side of opening and 20' ? ( if it is ) in front appears to be meet in the photos.
    ** This Label also carries an ISBO approval certification number that is still in effect.
    Sep 2008
    so so, California
    Good Morning Marc,
    I was thinking more along the lines of the installation of the box into the wall and clearances around the box e.g. side rear top etc...
    .I was thinking more along the lines of the installation of the box into the wall and clearances around the box e.g. side rear top etc...
    Do you have pictures of inside the chase?
    Sep 2008
    so so, California
    Yo... just one.
    Manufacture Fireplace Chase not installed per Manufactures Installation Instructions with Combustibles in contact poses a Fire Hazard :
