Thread: Geothermal System
02-09-2012, 03:08 PM #1
Geothermal System
Hello,
Can anyone tell me what the range of acceptable differentials between output and return should be on a Geothermal Packaged heat pump?
Jim
02-10-2012, 12:44 PM #2
Re: Geothermal System
Air or water temperatures?
02-10-2012, 05:41 PM #3
I can only give you the readings from my geothermal heat pump.
Climate Master
Tranquility 27 TT Series (2 stage scroll compressor)
10 KW electric back up
4.5 ton
superdeheater
Horizontal loop
Water temp of incoming 58.5F
Water temp of outgoing 53.6F
Return air temp - 71.1
Supply temp. 97.2
+26.1 difference
These readings were taken Sept 29/10
This is also a great site for geothermal systems.
Geothermal Heat Pump Forum
