Results 1 to 2 of 2
Thread: Metal Straps for PVC Pipes
02-15-2012, 10:16 AM #1
I see this all the time in new construction and rarely see the type of coated strapping designed to protect the drain lines and also resist upward thrust. How often do you guys see this? I mention it every time but the home owners don't really care unless something is damaged and I'm sure the builders are not changing it.
Similar Threads:"It takes a big man to cry. It takes an even bigger man to laugh at that man". - Jack Handey
02-15-2012, 05:23 PM #2
Re: Metal Straps for PVC Pipes
yeah see it all the tie and note it also, an indication of non pro work.
