02-17-2012, 04:21 PM #1
Air Conditioner A/C exterior drain line
Hi all,
Just wondering if there is a problem with an A/C exterior drain line that gives on a roof.
02-17-2012, 04:28 PM #2
Re: Air Conditioner A/C exterior drain line
The main problem I see is an opening which is inviting rodents and insects into the house through that expressway tunnel.
Condensate on the roof? Should not be there either, but if they address the item above, this will be taken care of too.
02-17-2012, 04:32 PM #3
I don't see a problem if the penetration around the drain pipe is sealed. It's just water being extracted from the air.
