    Andrew Grossman's Avatar
    Andrew Grossman Guest
    Default Light switch required
    Is a light switch required just inside the front door of a single family home that controls the chandelier hanging in the front entry foyer? Or is it allowable for that switch to be about 15 feet or so inside house, away from the front door?
    Default Re: Light switch required
    Other than for stairways and height, there are no requirements on the location of switches to control lights.
    That's one of the quirks of the codes ... the codes do not address stupidity, common sense, or the lack of common sense.
    Oct 2011
    Eastern Shore of MD, NEC 2008
    I think you missed one.
    210.70(A)(3) Storage or Equipment Spaces. For attics, underfloor
    spaces, utility rooms, and basements, at least one lighting
    outlet containing a switch or controlled by a wall switch
    shall be installed where these spaces are used for storage or
    contain equipment requiring servicing. At least one point of
    control shall be at the usual point of entry to these spaces
    The lighting outlet shall be provided at or near the equipment
    Oct 2011
    true.
    Dec 2009
    Florida
    Resurrecting and old one... Any changes to the code in this issue? I couldn't find any.
    Feb 2010
    Wenatchee Wa
    Does anyone know when it was first required that you need a switched light in a room. I see the 210.70 first shows in 1981 but was there another requirement that predates this?
    Don Hester
    NCW Home Inspections, LLC
