    Lawrence Carter's Avatar
    Lawrence Carter Guest
    Default stucco foam clearance at fireplace direct vent
    Hey there, first time user.... curious to find out how much clearance should be maintained between fireplace direct vent and exterior stucco foam trim detail installed at the exterior of the home??
    Default Re: stucco foam clearance at fireplace direct vent
    Quote Originally Posted by Lawrence Carter View Post
    If you look at the vent pipe it should have printed on it the required distance for combustibles. Most I have seen have a shroud built around them that the cladding abuts up to.
    Cool Re: stucco foam clearance at fireplace direct vent
    Stated clearances treat all combustibles the same whether wood, paper or foam so as Scott said, refer to the listed instructions or clearances marked on the venting. Note that many direct vent terminations are made in such a way that the unwary may not cut out enough combustibles allowing the pipe to get too close. Generally, there is an exterior firestop/ spacer installed first that ensures clearances then the termination mounts to this or is integral to it.
    Sep 2008
    so so, California
    Did you get a pic?
    Jun 2010
    San Luis Obispo
    Item of note, many DV fireplaces set the vent clearance based on testing. So with many models, in the manual is the clearance for that fireplace and it's venting.
    For example a 20k btu valor with duravent DV venting may be different than a 45k btu Mendota fireplace also vented with Duravent DV.
    Just saying it's in the fireplace manual.
    my2c
    S
    Smile Re: stucco foam clearance at fireplace direct vent
    Quote Originally Posted by Stephen Tilleux View Post
    my2c
    S
    Many DV fireplaces? Try ALL. It's part of the listing process through ANSI Z21.88
