Results 1 to 12 of 12
Thread: Recognize this nozzle on a wall?
04-24-2012, 08:06 PM #1
The center portion is white plastic, square with 4 smaller orifices. The outer housing has a firehose-style clip to accept a hose of some sort. The previous owner might have been a mechanic or bodyman. Not access for an interior view of this thing, and no sign of another pipe inside. Is it for compressed air?
Similar Threads:John Kogel, RHI, BC HI Lic #47455
04-24-2012, 08:42 PM #2
Re: Recognize this nozzle on a wall?
Termite treatment system for injecting borates into the wall cavities?
04-24-2012, 09:58 PM #3
I'd have to surf the web to know exactly, but it is an electrical receptacle of significant amperage, ( 40 to 60 amp prox ). They are most commonly used for welder receptacles. Cannot tell if it is a three of four wire device from the photo. These have a spring loaded covering cap that appears broken off this device.
04-25-2012, 05:48 AM #4
Exterior cap was probably broken at by same thing that broke the conduit nest to it.
Do vote for a electric welder connection.
04-25-2012, 06:27 AM #5
I agree with the two Garry's, but have also seen them used for an RV.
04-25-2012, 09:14 AM #6
Thanks, guys. The welder hookup makes sense. There are some unidentified breakers turned off in the panel.
04-25-2012, 10:36 AM #7
John,
If it was a welder look for a 240v - 30 or 50 amp double breaker.
Did you test to see if it was hot?
04-25-2012, 11:24 AM #8
04-25-2012, 11:56 AM #9
Could it be an older breather vent termination from a regulator or was there formerly a fuel storage tank on the property?
Looks like damaged raceway containing exposed wire to the left.
04-25-2012, 01:29 PM #10
It looks like a 'Hubble' Box connector. Welder or generator port.
04-25-2012, 02:11 PM #11
Hello All,
This is an electrical connector called pin-and-sleeve. Hubbell is but one of many manufacturers that make this. Being that it is on a house, a welder or backfed generator is a good guess.
These are used in all kinds of applications from factories and docks to touring stage shows and concerts.
Can't tell what size (amperage) from the pix.
Corey
04-25-2012, 02:44 PM #12
Yes, Gunnar, I did think nozzle, so I didn't test for 240 volts. It looked familiar but it didn't click. I went home with nozzle on my brain, posted it, then woke up thinking, 4 holes, it's a socket.
It would have tested dead anyway, because I believe the breaker was off. 40 amp supply for a welder, receptacle probably salvaged from a pulp mill or sawmill.
The cap is broken off, as Garry astutely pointed out.
