Thread: what is this siding?
06-11-2012, 08:11 AM #1
what is the trim covered siding? formed panel? stucco?
06-11-2012, 11:24 AM #2
Re: what is this siding?
It's probably that stucco panel or stucco board. Just 4x8 sheets embossed to look like stucco.
06-11-2012, 01:04 PM #3
06-12-2012, 03:43 AM #4
There are trim products for stucco that are carved styrofoam forms. Perhaps that's what these are.
03-15-2013, 08:58 AM #5
Older homes here in TX used a Masonite type panel that was stamped to look like stucco. These panels would last only if you keep them caulked and painted. Otherwise, water gets to it and it falls apart just like the Masonite panels that rot at the joints and the base by the ground from water splash off the roof.
03-20-2013, 10:11 AM #6
03-20-2013, 10:28 AM #7
I am unable to enlarge these photos, and haven't a clue as to what is there. All I see is grey.
I suggest you poke around and determine what is under the paint. (is there eps? plywood? masonite?), etc.
03-20-2013, 10:31 AM #8
Sincerely,
Brian Hannigan
Twitter: @InspectionNews
03-21-2013, 09:51 AM #9
